Simple question-- what do you all recommend in terms of the best way to save out highly-tailored Corona Materials into a beautiful, easy-to-use library? I don’t need a crazy asset management system-- really just materials.
Ideally, it would be something that would automatically scoop the texture-maps and re-save them in a folder structure automatically. I’ve used KStudio and design connector in the past a bit-- but wasn’t sure what’s good out there these days. I NEED to stop re-creating the same materials over and over again and/or importing models just to grab textures.
There are no Corona Portals any more, they are no longer required due to the Adaptive Sampler that was introduced in Corona 6. See the release blog at Corona 6 for 3ds Max released
I used to use this too, also quite good I have to agree. One thing I like about Project Manager is that you can build scripts with it easily to automate/batch tasks.
All depends on your pipeline, how you intend to use your libraries, how many licenses you need etc.
Yes, while I agree with Siger, Project Manager and Connecter being great options. Don’t forget the built in .mat library can also load .max files as well. Which means you can actually load your libraries from previous projects which use the same material names, and replace them using your favorites/previous authored materials from an existing 3dsmax scene, or just populate the .mat with that .max file. Its more powerful than you might take it granted for since there’s not many tutorials on the matter and whatnot, but its actually very powerful with lots of useful functions and from what I’ve seen over the years not used to its potential.
Attached is an example of loading a 3dsmax file with my favorite velvet, chrome, rubber materials etc. I can just re-use them from that project and then save them to my favorite .mat library if I choose to.
Another example is you can just right click on the chrome material > replace all “chrome” materials with this preset for example.
