Material library wont install Corona 8
Any suggestions?
Hi, what exactly is happening? Is there some error message? Nothing happens if you press the toolbar button, or…?
I have the same.
Removing previous installation of Material Library… done
Installing Material Library… Failed to download additional installer data (MaterialLibrary): Failed to send GET request to https://installer.corona-renderer.com/3dsmax/8/MaterialLibrary
Error: Połączenie z serwerem odwołań było niemożliwe lub nie można było uzyskać ostatecznej odpowiedzi.
Unpacking and installing…
Operation result: failed
Writing installation database… done
Installation finished
Edit:
Ok it worked. I installed the libraries manually.
You need to download them from the link https://installer.corona-renderer.com/3dsmax/8/MaterialLibrary.
Then copy them to the folder with the universal installer file. Open installer and update.
“Then copy them to the folder with the universal installer file. Open installer and update”
This part i dont get… where can i find that folder with what?
what “Arthi76” said happend to me.
I dont understand his workaround
You need to put Material Library file to the same folder with installer file (corona-8-3dsmax.exe) and run it one more time.
