Material name
when I renaming materials in Sketchup material editor, updated names does not appear in Vray material editor (In different direction everything works good). Do you know how to update names in Vray material editor?
Thank you for reporting this behavior!
This is a known issue, already resolved. The solution will be available in the upcoming update.
Kind regards,
Peter
The same happens for colour changes made in the Sketch up Materials using the colour wheel, they colour does not update in the Vray Material until the model is saved and reloaded. I assume this is all a part of the same fix :slight_smile:
I can no longer reproduce this, so yes.
Thanks for letting us know!
