I assign materials into the project through “edit type” of each structure.However, they do not show up in Enscape or Revit. Can you please let me know how to fix this?
@Mojkml , thanks a lot for joining our forum, I’m sorry to hear about this issue.
Have you made sure, that you setup the materials in the Appearance tab? They will be used for Enscape and Revit accordingly.
Otherwise, if that doesn’t help, can you send me a screenshot of the selected material, where I can see it not working in either Revit nor Enscape?
I am having issues with the revit to enscape materials as well. I have two different colors of the same material. The only way I can get enscape to show a material is if I change the tint, but it changes the tint of all 4 of the similar materials. How do I separate??? I’ve changed the color under the generic section under the appearance tab and graphics tab and neither change the colors in enscape.
I’m facing the same issue, have assigned all materials correctly in appearance tab, but the material colors of Graphics tab are showing up in enscape instead.
One point to be noted, the same properties work on other PC’s just fine and render come out with correct material ( its a central revit file) and all revit files are facing the same issue. Have uninstalled and reinstalled enscape to no avail. Please help!
