Material not working on Enmesh
Hi, I have some problem Enmesh not showing the material I put on.
Hello @ivan_volga ,
Thank you for sending your scene in the ticket.
You need to apply material directly to the Enmesh component, it overrides any materials that are used in the Proxy Mesh.
Moreover, Enmesh is generated based on the UV mapping of the object’s material that Enmesh is applied to. You can change Binding Texture Mode to Texture Helper to preview the UV’s.
Perhaps this tutorial will also be of help to you: V-Ray for SketchUp — How to enrich your project with Enmeshes from Chaos Cosmos
Thank you, Natalia!
