Material Opacity with Toon Shader Vray Next 4.1
Yesterday i realized, that VrayMaterial Opacity of Next 4.1 doesn’t work with the VRay Toon Shader outline anymore. On Vray Next 4.0 it worked with Material Opacity 50% (you could see half transparent oulines of the object through the material). On Vray Next 4.1 you have to set the Material Opacity to 0% to see it. At 1% (darkest black) and all other values of the Material Opacity the outlines are invisible. Because auf this i had to switch back to an older version, to finish a clients project.
I logged the issue in our bug tracking system. Thank you for mentioning it.
