Material Overide, Overide
Hi Guys, Vray has a check box in their material which is usually default to on called Overridable.
This way when you check a Material Override button in Render settings you can still for Glass or whatever to render properly. It would be great to pull this into Corona.
The Material Override in Corona has options for not overriding things like Glass etc. in it (click on Preserve in the render settings), and options for an exclude list based on objects or materials.
