Material override menu display issue
Hi, It seems that there is an issue with Material override menu. The complete menu with option to choose the overriding material only appears after Bypass the Render Node several times and selecting other tab menu of the render node.
I can’t reproduce this…
Does this happen for you for every .hip file?
Hi @bdancer , nope it seems random.
Well, I guess the only way to figure it out is to inspect parameter interface with “Edit Parameter Interface…” and see why it gets hidden…
Hi, still have the issue. Can you please check? Here is attached screen capture. thx
V-Ray for Houdini number:21030 hash:8096a58 from 30 Jan 2022 04:58 (build number:21030)
V-Ray Core 5.20.20 [6dceb5d2] from 27 Jan 2022
Hi @creac ,
Material overides have changed dramatically in the past months, and I think you are using a ROP that was created when the material overrides were in the materials tab, with the new V-Ray material overrides changes the UI is broken now. Add a new ROP and everything should be fixed.
Best,
David.
Hi @david.anastacio , great thanks!
