The new R21 build is really good! Thank you.
But I still have a problem with preview material on an object. When I use shared shader and texture with filter or layer shader. When you change the parameters of the shader filter, the texture in the view is lost. the material on the object is only displayed in gray. I wrote this issue long time ago https://forum.corona-renderer.com/ material preview #msg144767
Does anyone else have this problem? Is there a solution?
thanks
