Material Preview Not Showing in V-Ray Asset Editor
For the past few days, I’ve been experiencing an issue with the material preview in V-Ray’s Asset Editor.
The preview does not appear in the right-hand panel of the material menu, which is quite inconvenient.
I’m using the latest version of V-Ray (7.00.03) along with the recommended Nvidia driver (572.16).
I’ve already uninstalled and reinstalled the V-Ray extension for SketchUp, but the problem persists.
What can I do to fix this issue?
Thanks in advance.
Hello @pauline_tarboulier , thank you for posting.
As a first troubleshooting step please reinstall Microsoft Visual Redistributable: https://learn.microsoft.com/en-us/cp…-2019-and-2022
Download and install the X64 Search - Microsoft Bing version. Once installed please restart your machine and try using V-Ray in a new scene and let us know if the issue is still reproducible.
If this does not help, try another approach:
  • Stop SketchUp (in the Task Manager check if all SketchUp and vrayneui processes are closed, if not end them manually);
  • Check if there is a file (or several files) called msvcp140.dll in the Temp folder (paste %temp% in the search bar and the folder will open); (Important! Change only the msvcp140.dll files that are located in the Temp folder.)
  • Rename or move the file somewhere else (for example rename it to msvcp140_test.dll or right-click>Cut>Copy to Desktop);
  • Open SketchUp and open Asset Editor;
  • Create Generic material and check if the material preview is working.
Share the results please.
Thank you for your quick response.
It was your second solution that worked—thank you very much.
Have a great day.​
Hi @pauline_tarboulier ​,
Please note that in the latest V-Ray versions this issue should be completely solved.
It no longer requires you to perform any manual actions.
