Material Previews do not show up
Hi everyone,
for some reasons the material preview in the material manager, in the node editor and as well in the object manager do not show up.
I tried a lot ofthings to resolve the problem but without effect!
Here’s what I’d done so far:
  • Re-calculating materials
  • Disable and enable material previews in the settings
  • sign-out and -in from the licence server
  • switching engine types CPU, CUDA and RTX
Cananyone help please!? Without previews it is almost impossible to work on projects.
Thanks in advance!
Hey @marcus_gro , I’m sorry to hear that. Can you try to rename your preferences directory so it can be created anew once you restart Cinema 4D?
Apart from that, if the problem persists, it might help giving us more details about your setup, like:
1. What versions of Cinema 4D and V-Ray are you currently using?
2. Do you have other plugins installed besides V-Ray?
3. Are there any errors in the Cinema 4D log window (image below):
Hi Deyan,
thanks for your quick reply!
I also deleted the preference directory without any change!
My Cinema Version is 2026.0.0
Vray V7.10.02
My installation is about two weeks old and at the moment I only have installed C4D with Redshift and Vray.
In the beginning it worked perfectly but I missed the point when themal function comes up.
This is the only entry in the console under Vray:
Successfully initialized V-Ray 7 for Cinema 4D, update 1, hotfix 2 (API 2026.000, runtime 2026.000, V-Ray version: 7.10.02, revision: 442153fe, build date: Oct 17 2025)
I hope this info helps.
Thnaks and best regards
Marcus
