Material problem
I use the same material on two different objects in the same scene, one works and one doesn’t. How can I fix it? I use 3dsmax and corona
Did you check if problematic object has proper UVs?
Thank you! I went into modifiers/uv coordinates, and it seems that the problem was texture scale
You’re welcome!
