Enscape doesn’t read the material that are assigned per Object inside a block.
Let me expand this, the block is created on a layer without any material properties, inside the block there are different geometries and each one of those has a material assigned per Objects.
Everything works fine if I try to render the scene with Vray but Enscape doesn`t read any of the material..
Here is a screen capture of the Rhino Viewport the red and blue face of the columns are painted on the single face of an extrusion, the green grass color is painted on the patch surface inside of the topography, but the wood trellis material is applied to the group.
but when rendered in Enscape for Rhino ONLY the wood trellis gets rendered with the material applied to the group…any sub surface selected item that has a separate material applied renders only with the material of the higher level group object.
