Material Question & general forum question
Hi everyone,
my first question is about a certain material, which I have a problem with replicating.
Its called Exyd and I tried using a jpg. of water droplets and silver material but that didnt give the correct impression.
Any help or pointers would be greatly appreciated.
Second point is:
how come I cannot post a new topipc in V-ray for Rhino: General or any of the Forums?
Thanks guys!
Could you post a rendering of your material? Your way sounds good.
I would try a much higher bump multiplier and also you could try the vray noise as texture.
Ok, but how would I make a bump map out of that material?
NormalMap-Online I use this website. But I have to admit I dont know what to use where when it comes “Normal, Displacement, Ambient Occ. and Splecular”. You know what I mean? Like which of these fit in which options in rhino?
You could play with frequency and maybe octaves (maybe you need to change the noise type to get it working (perlin?)). So you could add a small noise over the large noise. Also bump intensity could be to high.
Depending on the type of Exyd you want to achieve I urge you to experiment by using a Composite texture, slotting two Noise textures (or Noise + Cellular) with different parameters (amplitude/frequency) and then trying different operators to produce a two-layer (shallow and deep) bump effect.
For problems with forum access and permissions, please send an email at support@chaosgroup.com
Kind regards,
Peter Chaushev
