Hi, i want to replace a scene material with a cosmos material, it would be nice to select a scene material using droplet and replace it with a cosmos material by drag and drop on the materyal preview on the top right of the screen..
Submitted on AHA Ideas (ENVISION-I-52).
Drag & drop of Cosmos materials is supported on top of the viewport.
Just drag the Cosmos material onto the surface you want the material to be replaced. Let us know if you have tried this workflow, and if you find it insufficient - let us know why.
Submitted on AHA Ideas.
I know, but if i have the same material on ten different objects, how can i change them like vray’s “replace material” option? Somethimes, dragging material changes all objects that have the same material, somethimes don’t. If they are components, all change, that is true. You see, i add cocrete material for example, but i can paint one group at a time.
I made a test, as you can see, only one row change all at once.
1- I create a group, multiply it and paint from outside of the group (that one changed materials all at once)
2- I create a group, multiply it and paint them from inside of the group.
3- I draw rectangles one by one, made each of them group and
a- Paint them on the outside of the group
b- Paint them from outside of the group.
Can you confirm that the Select all functionality does not solve your problem?
You said you have the material on 10 objects and you want to replace it. Steps:
- Pick the material
- Click the Select all button to select all the geometries that are assigned with that material
- From this point on, you can either modify the material, or even navigate to the Cosmos browser and drag/drop another material on top of this selection
It seems my licence expired today. By selecting all objects it will probably work. Thank you..
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
