I have a scene that just kept crashing while rendering that had the error listed above.
This morning i have re-modelled the whole thing from fresh.. Nothing crazy,just Box’s for walls,floor and window..
Using 2 materials
VRAY mat- Glass Diff-black / ref-250 refr-250
VRAY mat - RGB 200
The error keeps appearing saying Line 002 / Line 018 / Line 003 these are just box’s for walls.
Can anyone help figure out what is going on, or could this be a bug in Beta 3 ??
vlado
2
I can’t say right away where is the issue; can you get me the scene to vlado@chaosgroup.com so that I can debug it?
Vlado ive found the problem item..
Its when i turn on Spherical Full Dome with a HDRI sky map. Should this happen?
vlado
4
No, it should not… but I’m not sure where the problem is coming from. If you can get me the scene, it will still be very helpful.
ok.ill email but what do i do about the HDRi .its pretty large filesize
vlado
6
I can get you ftp info to upload it - just email me to vlado@chaosgroup.com
change HDR to 16/8 bit see if that helps… HDR map cause a lot of issues in my renders ;s
Been getting this error a lot lately too. Didn’t connect it with the the HDRI images, but I have also been having a lot of oddness with those.
b
vlado
10
Yep, it might the same HDRI brightness issue…
