material selection tag
Hey guys
can some one explain what i’m doing wrong, because I can not make material selection tag to work?
thanks
best regards
nuno
ps- i think this was already discuss here but i can’t find
https://www.dropbox.com/t/lUl24lBFOROXZ3gb
Hi Nuno, you just need to use two separate copies of the same material, it was like that also on 3.7 version.
Hi Stefano
thanks for the answer… but actualy on 3.7 we could use the same material wiht diferent selections and orientations…:S
that is a shame that we can not use a unique material but with different orientations… for that i prefer to split the roof and orientate the same material.
thanks anyway
here is a screenshot from the 3.7 version
best regards
nuno
Hello @nunomatos ,
You can still do that in V-Ray 5 for Cinema4D. Just keep in mind that you will need to use UVW mapping for the projection type of the materials. Please check this screenshot. You can also find a simple test scene attached below.
test_scene.zip (120 KB)
Hi @aleksandar.kasabov
thanks for this. I know that with proper UVW we can use the same material but you know that is faster to add a cubic projection map and adjust :wink:
but i’ll follow
best regards
nuno
by the way using UVW you don’t need to have selection tags or two material tags… but for that you will need to unwrap things:S
but thanks
nuno
EDIT: I was too quick to post. The results I was getting are using an internal version, apologies for the confusion I might have created.
can you send over that sample scene?
I tried to reproduce it on my side, but seems to work as you’ve expected
This is something i ran into recently too. For example, when texturing wood grain on cabinet doors, i used to use selection tags to isolate parts of the mesh for mapping the wood grain correctly.
I have attached an example c4d file with a couple examples that used to work in vray 3.7.
The other use case for selection tags is to instance geometry with selection tags(no materials) and apply the materials with selection tags to the instances. We use this to quickly create variations of the original object. This used to work in vray 3.7 and does not work in vray5, i believe it is related to the OP’s issue.
My current workaround is to split the mesh or generate uw maps from the cubic maps.
Selection Tags Issue.c4d (945 KB)
Hi Yanul
ahhh you get a previledge… :wink: hope we can get that internal to…:smile:
thanks anyway for getting that info
best
nuno
Hello all,
This seems to be a bug on our side and I have reported it (bug ID: VC4D-1292) to our developers for fixing. I will let you know once we have more information on the matter. Thank you.
thanks for clarification @aleksandar.kasabov
best regards
nuno
Hi all,
This bug has been fixed and the fix is now in our latest stable build. You can download and install the build from here.
Thank you.
Hi @aleksandar.kasabov thanks for the update. i’ve confirm right now and its working :wink:
best
nuno
Runs very unstable here.. especialy when i load big textures and disable mipmap it crashes very often. I downgraded to the februar build and the crashes disapeared.. sad i realy ned this bugfix with the selection-tags
Hi @tomschmid , can you provide more details on those crashes? Can you tell us if are you using V-Ray GPU and some hardware specifications? Are you using classic materials or node materials? Also if you can provide a simple test scene reproducing the issue it would help us greatly to find the reason.
Thanks in advance.
Hi Tom
sorry to ear that… on our side we didn’t notice any crash even reproducing your description… but… :wink: hope you can solve the issue
resuming, right now all working here
best
nuno
MacPro and with classic material. I just load a big 6k texture (15mb) and put mipmap to none and it crashes 90% of the times. So it crashes while i editing the material and not when i rendering. I have not the time to make more tests. I already downgraded and the crashes are gone. Will have to test it later with a new release again…
i’m now working (editing materials) an hour in an old vray 3 file without any crashes (VRAY 52001 220214). same file i worked yesterday with VRAY 52002 220402 which gave me crashes every 10min. But i could reproduce the crashes even in a new file. So i dont know exactly what it ist, but editing materials is much more stable here in the old build
Hi, is it possible that you are hitting the MacOS file limit problem (some more details on the problem here). Can you check if rising the limit (with the command I linked in the post) solves the issue?
no i already use the terminal command… i know this problem
this would also affect the old build.. but once again. i dont have the crashes when im using the old build.. not a single crash this morning.
yesterday i had 20-30 crashes with the new build and im doing the same work.
i can test it again later when i have less work. i thougt perhaps some other person has noticed some instability with the new builds. seems im the only one so far
