I’m trying to have one material override the environment map like in the following thread:
I tried Yolov’s test scene and CPU works great, GPU not at all.
I’m working in VRay Next for Maya 2019.
Cheers,
Lennie
Cheers,
Lennie
Thanks for the report! I’ll make a note about it to our developers for further investigation.
EDIT: My bad, reflection material overrides are currently not supported on the GPU. You can see a full list of the supported features in the technical documentation here: Chaos Docs
Ah right, Thank you for looking into it ![]()
I was able to achieve near enough what I wanted using a second light dome and light linking.
