Material tag coordinates issues
Hi everyone,
There is a bug with the material tag stack on one mesh with multiple selection.
In this case, the cubic projection with differents coordinates doesn’t work with the same material but works with another material.
Hi @christian_clouet , this is a known limitation that may not be resolved soon. As a workaround, you can try splitting the object or cloning the material.
Ok ! thank you for your answer.
Hello @christian_clouet ,
This bug has been fixed and the fix is now in our latest stable build. You can download and install the build from here.
Thank you.
