Material texture not showing in the slot
Hi guys,
I’m pretty new with Corona, so this is my first question.
I cannot figure out why my final slot doesn’t show the concrete texture in the map.
This happens for some slots, not for all of them.
Any idea about this issue?
It’s because you are probably using real world scale for your textures. you can change the default dimensions of the preview sphere by right clicking and going to options. then change the render sample size. But note, that in changing the dimension to accommodate something with a large real world scale all your small textures will look small and repeated. so you may have to find a balance that works for your project.
see attached.
Also in the future you should post this in the “I need help” section of the forum.
