Material Update . . . . .
i import a model and get materials like . . ,
V-Ray Proxy - XXX.vrmesh_ID
V-Ray Proxy - XXX.vrmesh_ID_0
V-Ray Proxy - XXX.vrmesh_ID_1
V-Ray Proxy - XXX.vrmesh_ID_2
V-Ray Proxy - XXX.vrmesh_ID_3
and i was add Reflection in V-Ray Proxy - XXX.vrmesh_ID_0, add bump in V-Ray Proxy - XXX.vrmesh_ID_2 and add reflection + refraction in V-Ray Proxy - XXX.vrmesh_ID_3
File save perfectly . . . . . but when i import the XXX.vrmesh as a component every time V-Ray Proxy - XXX.vrmesh_ID_0 material was rest . . . . . .
but V-Ray Proxy - XXX.vrmesh_ID_1,V-Ray Proxy - XXX.vrmesh_ID_2,V-Ray Proxy - XXX.vrmesh_ID_3 material was import perfectly . . . . .
any SOLUTION about that . . . . . . . ?
THANKS
Sketchup Master
Could you please specify the exact SketchUp and V-Ray version that you are using ?
Now i’m using V-Ray For SketchUp v 1.6.23 Beta_win_x86 version . . . . . . . .
Hi again,
Thank you.
I managed to reproduce this issue here, but it seems that we have this bug already added to our system.
So i will make an update with the reproduction steps you have posted.
Thank you sir,
can you tell me when you launch your new beta test version of V-Ray for sketchup 1.6.-- . . . . ?
we are waiting . . . . . .
thanks
the next beta release will be in the next week or two, there will be an announcement as there were with previous releases.
ok thanks . . . . .
