Been playing around with materials, and if setup correct anything is possible with Enscape. Great job, look forward to using this on many projects.
Great images, thanks for sharing! The lighting looks good in this scene. We’re working on another update that ensures this kind of correct reflections and lighting in all kind of architectural scenarios.
wow - that last one is very nice. can you pan around in that view or does it get to ‘heavy’?
Jorgensen
Wow, the image looks great!
I have zero issue panning around, the program seems to be able to take very large poly counts with ease. Im running on a 980TI so that helps im sure but i have seen zero lagging so far in all of my testing. Im very impressed with enscape. Im a long time lumion user and once i get my workflows down and enscape evolves a little more i dont see why i would continue to use lumion.![]()
Looks great but how did you achieve an emitting light in 2nd image?
Those two are out of revit and the lights are from the manufacturer and include ies files for the light type. The third image is from sketchup and as of yet i dont believe we can do lights in sketchup and i dont believe there is an emitter material yet. At least not that i have found. Sorry, little confusion mix of revit and sketchup.
We are currently not supporting lights in our alpha for SketchUp, but we are working on it and will support it in the future.
Hi Scottofazphx, where are the lights from, wich manufacturar, or is it possible to share to me that part wich include the lighting, I did not succeed yet in getting such great result yet in Revit. Keep up your nice work! Thankyou, Remco
These are straight from https://bimobject.com/en this particular light is from the manufacturer Focal Point I believe. Really the key is a good manufacturer and make sure they include the IES files and that that file is in your revit search path. I have tried a couple and have had really nice success
Great tnx, I give it a try, already some results and experience with BIMobject
On this last release there has been a change to the shadows and im not convinced its for the better. I apologize for my boring scene, but i use the same scene to test different releases so i have some type of control to see the changes. If you look at the images at the beginning of this tread you will see pronounced shadows under the chairs and elements where they should be. On this latest release they are GONE!!! am i missing something, have there been additional setting added that is have missed. Look at images below especially at the base of objects and then compare them to ones in original post. Is this a bug in the latest release? Help, dont want to go backwards in image quality.
UPDATE: After looking more closely they are there, maybe they are just more accurate and im used to them being darker. Thoughts everyone!!
I think the new images look great. The shadows were previously greatly exaggerated. Have you ever seen a chair with a black dot around it due to his shadows in reality? Although the contrast underlines the geometry, it usually looks fake or like computer imagery. However, there is an “ambient occlusion” slider to add this darkening. I recommend to keep it as little as possible.
Thanks for sharing the images!
Thomas,
You are correct, the more i looked at the images and compared them, the new versions is much more accurate…thank you
