I received some Revit files, when I import them into Enscape, the materials appear grey. Do I need to manually define the materials for all the elements in all the received models, or is there another way to ensure they display correctly in the rendering?
Looking at that, is that a DWG that’s linked/imported in or embedded in a family? If so, you’ll need to add materials to the dwg layers by going to Object Styles, and then Imported Objects…
Otherwise, you’ll need to open the Revit families/project files and interrogate as it could be that parametrically, materials are not set up correctly.
