Recently, I have switched the Enscape liscence to a new computer and been having this issue: the materials and lightning are not working properly, as seen in the screenshots. Has anyone had similar issues and can help me with how to fix it? Computer’s graphic card driver is up to date and all the Enscape settings are the same as they were when I was using it before on other device.
Welcome to our Forum.
Can you please let me know a bit more about your system? What is the graphics card model which is built into your current machine?
You can also generally check if the machine you switched to supports Enscape here:
https://learn.enscape3d.com/blog/knowledgebase/system-requirements/
If it does, then you can also submit us a feedback report with logs which will allow us to troubleshoot this further.
Thank you very much in advance for any further replies.
