materials not showing true to colour swatch
Hi Demian
I am hoping you could help. I have created a custom material in rhino, but when rendered the colour is showing far warmer with red undertones in comparison to the actual colour swatch.
I have tried adjusting the lighting in both rhino and Enscape, but seems not not be working.
I have attached the swatch and render output below please advise
There will usually always be some sort of color difference when it comes to how the material looks in the preview/editor (in Rhino) and in Enscape itself, due to many different factors that have an influence over the appearance in Enscape like lighting/lighting color especially (which changes dramatically when adjusting the time of day for example) - Right away, can you please share a screenshot of the color swatch you mentioned alongside another image of the rendering output of Enscape as a whole (so I can see the scene better)? It seems the first has not been attached at all.
Thanks Demian. I’ve attached it here. I have also played with the lighting as mentioned (daylight sunlight, completely removing it, and inserting rhino lighting - but with very output, it comes off with a red undertone
that’s the sample swatch v how it is applying - it shows as an entirely different wood colour
