Good Evening
When I am in the V-Ray Asset Editor and move material from the Content table to the Material List , the material is not added to the list of materials in SketchUp
How can I fix this ?
( I have SketchUp Pro 18 and V-Ray 3.60.02 )
Thank you very much !
Could you please try the following:
- Go to - C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\ruby\special_objects
- Copy and Replace the file attached
Our developers are aware of this behavior and a solution will be implemented in the next update release.
vray_to_sketchup_material_translator.zip (3.34 KB)
I did as you wrote and it works properly !
Thank you very much !!
It makes so good to know that real help ia available !!
Same problem - just wanted to say thanks for the fix.
Great it works! Thank you !
боролся с такой же проблемой. Загрузил файл в special_objects . Все! Высший пилотаж! Огромное спасибо за помощь!
I am having the same problem (I haven’t tried the fix), but I want to mention that this problem started in 3.60.02 and I just jumped from .01 to .03 and it just started happening to me. So it seems to not have been fixed in .03
@mfrazierVCBO We were aware of this issue occurring, however, it has been resolved in the latest update (3.60.03) as confirmed by users previously experiencing it.
Regardless, could you please advise what OS and SketchUp version you are using? Does this occur with specific project or any? Could you please provide screenshots to illustrate the behavior on your end?
@georgi.georgiev I have since loaded the fix and everything is all better. Windows 7. SU: 18.0.16975. It was happening in all projects prior to the fix.
