When applying a material with a bitmap texture to a surface, the texture “sizes” with the surface. In the attached example, a stock V-ray wood plank material is shown on planes of different sizes. Changing the texture placement settings ie; tiling, seems to have no effect. If a scene has multiple surfaces with the same material that need to be uniform, such as multiple floor levels of different sizes, how is this accomplished? Thanks
Thank you!
