Materil ID Render Element AA Settings
Hi Everyone, i’m new to vray, how and where do i activate/switch between Color(AA) or Integer (noAA) when creating the MaterialID Render Element, as explained in the docs?
Thanx Chris
This is a Copy/Paste error from 3dsMax documentation. Those options are not available in V-Ray for Maya.
I’ll log a note about that into our system and our Docs guys will take care of that.
Meanwhile Material ID element it V-Ray for Maya outputs only Color values, it’s possible to enable/disable AA and Filtering but not possible to switch to Integer values.
If you would like to export Integer values use other elements like MultiMatteID or RenderID etc.
