Enabling the 3ds Max material swatches from V-Ray Settings can be used as a temporary solution. Apparently the nightly fixes it.
Hey all!
We’ve fixed the issue and our builds are updated - you can download them directly from here.
Thank you!
Anyone know the build number of this updated release? We just installed the nightly yesterday (which fixed it). Just curious if anything else had changed since then. build 32375
I’m not sure it’s helpful but the build number from the About V-ray rollout is 6.20.00 build 00001.
Thanks. Sadly they must use different build numbers for releases vs. nightlies. Kind of unfortunate. It looks from the release notes that a feature was added regarding multi subtex that is not yet in this build. Of course I don’t know if it’s in the release build because of the unrelated build number. This is why consistent build numbers and copious release notes are helpful to us users as well :o
We will roll with this version for a while until there is an issue or a new feature needed.
All fixes go like this:
internal nighlies → stable nightlies → official release builds
so if you are using the latest stable nightlies you will have all the fixes.
The subtex fixes also went into the release build - they and the material issue in this topic are the reason for that new build ![]()
Build numbers are unrelated because the build contents is unrelated
The 6.20.00 build 00001 release follows the initial 6.20.00 build 00000 release (numbers are consistent) and has some additional fixes. It won’t make much sense to have similar build numbers as the nightly builds because release builds follow their own path. Some fixes from stable nightlies go to the release branch but not all so if the release build had the same numbering - it would give the wrong impression that it contains all from stable builds with lower number.
Ah, interesting. I didn’t realize that release a complete separate branch from stable, rather than just a tag. Interesting. Thanks for the explanation.
So it sounds like I need to update (the entire farm) again to get the subtex fixes. I may give it a bit until things settle down. Thanks again.
I have the same issue max 2024, and latest vray, also i am finding it slower of larger model and the lighting lister is not showing lights and the model is not listing lights either in the layer system, very odd, all built in Vray, not a conversion..
same here… since update 2… had no issues before and see this the first time.
is there a way to force to render the thumbnails without switching the renderer and back to vray? because you loose all the settings if you do this in a scene with render setup.
best regads
themaxxer
The updated installer version 6.20.00.00001 already has a fix for this - just install it and you won’t need to switch renderers or force anything.
Thanks for the fix
I think many people don’t visit the forum regularly so they will miss this minor update.
There was no email sent for this update, nor the vfb showd the new update iirc.
The installer name is exactly the same so unless you know when was the official release and compared it to the date under the download link you will miss this update.
You are right - bumped the notification version in the VFB.
