Matte shadow bug?
Banging my head against this until I just discovered that using a blend material on a matte object cancels the affect reflections.
Tried using a wrapper but no joy.
Did I understand correctly: you have an object with a reflective VRayBlendMtl, and those reflections are not showing when the same object is a matte surface? I can reproduce this, but I’m not sure why you’re using a VRayBlendMtl for the matte in the first place.
The blend material is a label on a bottle, giving matte and shiny areas. It doesn’t actually matter in this case and I can deal with a swap, but as it was showing nothing at all it took a while to find the cause.
