Why can’t we do this, only virtually?
You can, you just need a metric shit ton of cubemaps from whatever scene you render. They literally take a 360 camera, shoot a shot, step a 5 to 10 feet from the previous point, shoot a shot, rinse, wash, repeat. Then in whatever tour app you use, set it to blend between frames you load. Done and done.
I remember Microsoft developing this a decade ago; it is good to see it being used. I suppose a 360 of each space isn’t much different, other than being able to move inch-by-inch. You would think we had a one-click solution to burn everything in and a viewer to walk around.
Yeah! The quality isn’t up there, but the idea is right. See, it can be done.
VR enabled, too. How did you get outside?
I just walked straight through the bedroom window
