max 2008 vs max 2009
I am not sure if this has been discussed already… If yes, excuse my french !
So,
Recently i am working mainly under 2008 and i would say, i am quite happy with it…
Stability, etc, bla bla… yes, sometimes it just blows out without any warning what-so-ever…
So, anyone tested both and has an oppinion ?
Would be great to know … or to wait for some SP.
nikki Candelero
I would say that its worth switching to max 2009, just because of its navigation cube. I mean come on…it has occlusion shadow!!
:smile:
I’ve been using max 2009 64bit now for over a month and I have discovered Lots of annoyances, probably safe to say bugs, that are making me second guess my choice. Here’s some stuff I found to be annoying:
-2009 will crash left and right without grabing the hotfix from autodesk which is still in an unofficial release condition last I checked.
-I disabled viewcube as soon as opened 2009 for the first time. What can be more simple then hitting “T” for topview, etc.
-Photometric lights tend to randomly reset their energy values on scene load
-Viewports will regularly pop out to Perspective view just by clicking or dragging an object
-Half the time, the viewport you have chose to work in isn’t fully functional without selecting it for a second time (walk thru mode sometimes unavailable inm perspective view on first try)
I can’t say anything about the performance boost yet because I havn’t used it long enough but the latest nvidia drivers for the 8800gtx don’t seem to work well in directx mode, major graphics gliches.
Ok I’m done for now :slight_smile:
viewcube is horrible
new select by name is horrible
new render region/crop scheme is horrible
Can still get it to crash when appending material while texture is visible in viewport
Hate that the mat editor defaults to a bunch of mentalray mats.
All I can think of for now.
hahhaahahahahahahahahaah u got me :slight_smile:
The select by name you can change back to the old one just by editing the ini file in your user profile max folder
"C:\…\…\AppData\Local\Autodesk\3dsmax\2009 - 64bit\enu\defaults\MAX
then edit the CurrentDefaults.ini file and change
SelectByNameUsesSceneExplorer=1 to SelectByNameUsesSceneExplorer=0
I totally second that, and I think I’m going switch back to Max 2008 for my next project.
It’d be good to get these remarks infornt of someone over there at Autodesk. One thing I did notice, which blew me out of the water, is that I actually got a reply to an error report from someone at Autodesk. Who knows, it’s worth a shot.
Can’t seem to get that ini file change to work. Any ideas? I’ve changed it to ‘0’ in two different ini files but it still loads as before.
Yeah, you have to find the correct one. It writes like 8 of them to various places on your HD unless you disable the settings per username feature, and path all user paths to your C:\Max2009 folder.
Search your whole C:\ drive for *.ini
mmm… I’ve tried in the following locations but can’t find anymore:
C:\Program Files\Autodesk\3ds Max 2009\Defaults\DesignVIZ\FactoryDefaults
C:\Program Files\Autodesk\3ds Max 2009\Defaults\DesignVIZ.mentalray\FactoryDefaults
C:\Program Files\Autodesk\3ds Max 2009\Defaults\MAX\FactoryDefaults
C:\Program Files\Autodesk\3ds Max 2009\Defaults\MAX.mentalray\FactoryDefaults
I may have exaggerated…
Actually, there should be some here, if you have relative user paths:
C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\3dsmax\2008 - 64bit\enu
I’m in 2008, but I think this feature works the same way…
Odd. I only seem to have a 3dsmax.ini file in the following location, and it doesn’t have a ‘SelectByNameUsesSceneExplorer’ string in it:
C:\Documents and Settings\richard.birket\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu
There isn’t a CurrentDefaults.ini file in there.
Found it! It was in:
C:\Documents and Settings\richard.birket\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\defaults\MAX
Not sure why searching the whole C:\ drive didn’t find it? I even had show all files etc switched on.
Okay, just checked on my test build where I have 2009. I have a CurrentDefaults.ini in these folders:
C:\3dsMax2009\Defaults\DesignVIZ\FactoryDefaults
C:\3dsMax2009\Defaults\DesignVIZ.mentalray\FactoryDefaults
C:\3dsMax2009\Defaults\MAX\FactoryDefaults
C:\3dsMax2009\Defaults\MAX.mentalray\FactoryDefaults
C:\3dsMax2009\Defaults\MAX.vray\FactoryDefaults
C:\Documents and Settings\aaronc\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\defaults\MAX
EDIT: Oh, sorry. You already found it.
Thanks for your help Clifton
I’ve found a way to change to render region mode quickly, in customize i set up a shortcut key to “Edit Region”.
Now when i want to change from render view to render region i press my shortcut and render region marquee apears in the viewport.
But i don’t know how to change from render region to render view without enter in thr frame buffer.
