Max 2010 Material Libraries
I’ve been trying Max 2010 on a small job as a test before before rolling it out across the department. Unfortuanately I’ve found quite a serious bug. It appears any material libraries saved out of 2010 are corrupt. Basically it strips out any bitmaps used in materials. I’ve done a search and found others with the same problem but no workaround or fix.
Is anyone else on here using Max 2010? And have you found a workaround?
Any help would be very welcome,
Dan
