hello all,
quite self explanatory…wanna use maxes render region, not vrays, as that youne is quite slow to use…
any ideas where i can find the goo old button?
thanks a lot
hello all,
thanks a lot
You can find the controls in the Common tab of the Render Setup dialog (F10). I am not sure you can bring it to a toolbar as a button though.
yes!! You can! :d:d:d:d
any idea how? was trying it for abou half an hour but then i gave up…where is it located in customize user interface??? maybe i just did not see it
In Max 2009, you can go to Customize-->Toolbars-->MainUI-->Render and add the “Edit Render Region” to any toolbar. Might be in a different place in 2010 though.
nope not there :((((
The “Edit Render Region” button is ok if you want to resize your render region but it is useless if you want to desactivate to render a full view.
Maybe i’m wrong but it have to be another button to activate or deactivate the render region like in older versions of 3dsMax.
Quickly scanning this thread, I think you’re looking for the “Area to Render” dropdown menu located on the Rendered Frame Window?
That lets you choose View/Selected/Region/Crop/Blowup…
Edit: Took the time to read the thread now, you want to customize it, not sure…
Edit2: Not sure there is a preset custom option, but you could write your own MaxScript with setRenderType region and put that anywhere you want…
OK SnipeyX, thanks for your tips…ill have a go at it when i have some spare time
