max 2016, V-Ray Next, vue extreme - DLL error & crash
Hi guys,
I’ve recently upgraded to Next from 3.6 running on max 2016 but I can no longer render vue extreme scenes via V-Ray, I get the Plug-in DLL error attached before max crashes. Rendering with Mental Ray still works fine.
Is there a way I can access 3.6 in the render setup dialogue to render vue scenes with V-Ray still? I have online licensing, and have seen on other discussion threads that older versions of V-Ray are usually accessible when you upgrade.
Thanks for any help.
Jon
Bizarrely, I also get the same error when opening pFlow, even in a new scene. Clicking on the OK button causes it to pop up again 3 or 4 times before finally opening the Particle View window, and max doesn’t crash.
Hi Jon,
The error shows that the xstreamvray3.dlr cannot be loaded. I guess it is compiled with the V-Ray SDK, but for V-Ray 3, so you should update with a V-Ray Next compatible version.
About the particle flow is the error message about the same file? If it is then the update should solve that too.
Alexander
Hi Jon,
The error is with the same plugin, so it will be fixed with the other one.
Alexander
Thanks Alexander.
Jon
If you use the latest license server - Download | My Chaos
you can just install a V-Ray 3.6 build and it will work with the Next license - https://download.chaosgroup.com/downloads/5095/vray-3dsmax-2018-36004-adv
@MonosP Did E-On ever get back to you about the Vray Next version? The very latest installer still only lists Vray3 and I only have Vray Next installed here. Their product page for Vue lists Vray Next but it’s not in my installer.
Hey @wallworm , they did, the guy who dealt with my ticket got back to me quickly and with a detailed reply which I’ll post below, bear in mind this is from mid-August.
I’ve not had to do any significant Vue/V-Ray work since then but as @ivan.slavchev suggested I installed a 3.6 build when I needed both working together. I did have a couple of issues with network rendering and checking out a 3.6 workstation license for offline work but I need to go through that again to make sure I wasn’t doing something wrong before flagging it.
Hope this helps anyway…
E-on’s reply:
First of all, sorry for the long delay in coming back to you. A bank holiday day and the traditional holidays month in France created some delays where there shouldn’t be any. However, this is what our developers team answered – when I asked them to be sure to give you the right answer.
xStream 2016 is supposed to support all V-Ray 3.x version until the latest one which is 3.60.04.
For Ozone, it should be the same, but I can’t be sure because at the time of its release, we probably only tested with V-Ray 3.60.02 or 3.60.03.
We also have plugins for V-Ray 2.4/2.5 in 3ds Max / Maya 2015 and older.
So the answer in fact is – we do not have a V-Ray Next SDK yet – and the emphasis is “yet” I would say. One thing is for sure. A change for Vue xStream 2015 will not happen, so if you want to have a chance for an update, I think you need to upgrade to xStream 2016. But maybe you wait a bit with that, the schedule is to come out with a new version later this year, maybe this will change things (we are in Alpha testing at the moment and the decision what goes into this and what not is not done completely – of course an information that is a bit confidential)
I hope this helps you a bit, even when it does not bring you a solution to your problem.
[quote="MonosP, post:7, topic:90169, username:MonosP"] \[/SIZE]\[/FONT]\[/COLOR]\[/LEFT]
Hope this helps anyway...
\[/QUOTE]
Thank you for the info. I grabbed Vue XStream for Max 2019 but they still have not added VRay Next for this version. I'm wondering if maybe Vlado or someone at Chaos can reach out to E-On and help facilitate an update.
[/quote]
Will see if we can do anything about this. The first beta of V-Ray Next was released a year ago and the official release is available since May 2018, that should have been ample time for the Vue guys to prepare and release an update.
Thank you Vlado.
E-on added Max 2020 support… but installers still only support V-Ray 3. Anyone have word about progress on them getting V-Ray Next?
Got an email from E-On today. They said they added VRay Next support.
I installed latest Vue for 3ds Max that purported to have added support for VRay Next. I set renderer to Vray Next, loaded a default Atmosphere from Vue’s default collection, hit render, then Max crashed to CER.
VRay had this error:
error: UNHANDLED EXCEPTION: Scanning scene Last marker is at D:\cgrepo\vray\vrender\src\vrenderlight.cpp, line 555: Exiting VRenderLightObj::init()
Hi, I’ll try to test it, but I am waiting for my trial application to be approved. In the mean time, which version of V-Ray Next are you using?
Alexander
I’m using Vray Next Update 2.1 . Thanks for looking into it Alexander.
I have my trial. The installer detected the V-Ray Next installations and seem to be working. I could render it with both the stable build and the official builds on the site (4.20 and 4.10). I’ve attached the scene. If the problem still persist can you try to uninstall V-Ray for 3ds Max. Then remove all files that start with “vray…” from the 3ds Max directories “C:\Program Files\Autodesk\3ds Max 2020”, “C:\Program Files\Autodesk\3ds Max 2020\Plugins” and “C:\Program Files\Autodesk\3ds Max 2020\Plugins\vrayplugins”. And install again so we’ll be sure that only actual versions of the DLLs are installed.
Alexander
testVUE.zip (4.18 MB)
Thank you Alexander. I will test these out as soon as I can. Note that in my test I loaded an atmosphere from the Vue > Atmosphere menu in Max (I forget which specific atmosphere at this time). I probably won't get time to test again for a few days but will share my results when I do.
