max 2023.2 crashing when closing render setup dialog
hello,
the new max update crashes 100% of the time, when closing the render setup dialog.
Apparently this issue only occurs with corona, vray seems to work fine.
tested on 3 machines.
Which version of Corona, please? Also which OS?
Not happening here, Corona 9 Daily from Sept 12th, Win 10. Also I have devel/debug open too.
corona 8 hotfix 2
win 10
here is the 3dsmax forums thread:
Oooh now it has started happening to me too, ever since I tried pressing F10, now I get the crash even after restarting Max. Strange, as I hadn’t run into this before and I updated Max on the day of their update. Anyway, giving the minidump from my crash to the devs.
Hey,
Thanks for reporting this to us. We are looking into a fix for this already and have been in contact with Autodesk.
I will let you know when I have some more information.
Cheers,
Rowan
(Internal ID=965678469)
thank you!
also, for anyone thinking of updating, don’t.
There is another bug, stopping you from opening scenes pre-update.
same problem here with the render dialog.
(and plus that, install of 2023.2 kind of doesn’t work on windows server 2012r2, AUC problem with ADSSO)
Strange one. If you start max, and do a (Corona) “Reset settings” in render setup → Scene, it is not happening. And additionally you can load any (other) scene without this issue subsequently using that max instance. I compared all renderer properties before and after the reset and restored them exactly as they have been → no issue as well. So maybe related to Render setup → system settings. I cannot see any difference in the files storing the system settings though.
Any reference, or just personal experience?
Good Luck
Had it happen to me today. Seems to be related to the chamfer update.
Thanks for the additional information. I remember at least having corrupt stacks using chamfer in the 2021.1/.2/.3 update path as well, but no hangs.
Good Luck
I can only imagine what mess it will be when 3ds Max will get boolean as a modifier. I developed a habit to always collapse the stack and reset transforms as soon as possible and potentially that saved me a lot of headaches, but unfortunately that’s not always possible with WIP files and when upgrading the Max, those files suffers the most :[
Speaking of current issue, how likely that autodesk will issue the fix? Or we’ll have to wait till next update?
this is from 4 days ago:
As soon as possible is the time frame we are at. A fix for the issue is currently being tested internally (thank you once again to those that provided sample scenes).
Once that has been verified as good we can start the formal build process, and then the delivery process.
Hey guys,
We managed to fix the crash in the v9 daily builds: https://forum.corona-renderer.com/ Chaos Corona 9 for 3ds Max - Daily Builds Changelog #msg203570
Thanks,
Rowan
that was fast!
any chance we can get a hotfix for v8?
Right now we are not planning on that, we have been in contact with the guys at Autodesk and they are looking into a fix for 3ds max itself.
So hopefully they will manage to patch it and fix the root cause.
Cheers,
Rowan
did 3dsmax 2023.2.2 fix this for anyone?
For me it’s not crashing, but i’m using latest V9 build, which has fix for the issue and Corona is not set as default renderer in my Max.
Still on Corona 8 as I need a stable release for production - 2023.2.2 did not fix the render setup crash here.
its not fixed in the 2023.2.2 update.
you can set any renderer that is not Corona to default and then have to switch back to Corona every time, to avoid the problem.
but that obviously still sucks.
last few weeks were rough, yesterday this issue also prevented me from sending jobs to the render farm. I was up till 2:00 AM uninstalling and reinstalling max didn’t help. I have to finish 3 projects by mid next week. why is this happening? so no fix to 8.2? why?
