Anytime I try to pull down the modifiers menu (once I selected an object), MAX freezes for a minute or so, then comes back, but no menu.
This happens with any scene, even a blank one (default).
I “repair” the installation, from Windows add/remove software; I “repair” from the MAX7 disk; I un-installed and re-installed the software…Nothing to do.
When you uninstalled did you make sure the directory was completely emptied?
I believe max would leave 3rd party plugins, etc in those folders and if there is something corrupted there it would continue with a fresh install if the directory wasn’t cleared out. Something to check anyway.
