Max crash on render end
Running a project where every time the render completes, 3dsmax crashes (Application Error) and it wants to send a report to Autodesk. Running Max2019 with VRay 3.60.04 on a Win10 machine, threadripper CPU, 1080Ti card with 64GB memory. There are a few XRef scenes with the project. Can anyone suggest something to try, or could Chaosgroup have a quick look? This is an animation job so time pressures are on :wink:
Could you send a crash dump - it might give us a clue.. (located in %temp% and called 3dsmax_minidump.dmp).
Yavor
Thanks Yavor - I’ve just PM’d you a link to the file.
Yavor - should I raise a support ticket for this? If so, what is the best way?
Hey Richard,
Lets see if Yavor will manage to find some useful info from the dump first and then will decide how to proceed further.
ok - I can provide a link to the archive of the file if that helps?
The crash happens in some MultiTexture texture while Max is generating its viewport preview - not much V-Ray in this :slight_smile:
Nevertheless - if you can send the link for the scene - we might be able to find out why if there is some workaround possible.
Thanks Yavor - I sent you a PM with a link.
