MAX Crashes everytime
Hi Gurus,
I am experiencing a very annoying crashes of max (2016) with Corona 1.4.
Whenever I use Interactive window in the one of the viewports… while refining shaders etc. … So if you (Alt+W) extend the working viewport (to avoid the interactive ) and go back (in order to have the INT.viewport to ask me to click on it, to start rendering… MAX Crashes…
I am sure this is somehow related to Corona 1.4 as it wasn’t doing it with 1.3.
Currently the only way to dodge the crash is - to hit < real RENDER > in order to interrupt the Corona activeshade… then stop the render and go back… Then the viewport is waiting for a click to start.
Please, help…
nikki Candelero
Max 2016, Win 7, Corona DB jun 12, cannot reproduce it - i can Alt+W while IR in viewport is running without any problems.
Can you post a minidump with the problem?
where is the minidump located ?
  1. Reporting crashes using Autodesk Error Report window: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
do you have the minidump? is the rpoblem still happening?
cannot reproduce
