Max Crashes when IPR is running and I update the xref materials file
Max crashes every time I update the xref materials file while IPR is running. Let me know if you need the scene. This doesn’t happen with RT CUDA Active Shade. Screenshot below.
This should be fixed already in the latest 3.6 builds.
Thank you!
I confirm that after installing 3.6 this no longer leads to crash. Thanks again for fixing this! :slight_smile:
That is good to know :slight_smile:
