max Distance to Reflections/ Refractions
In other Renderers there’s a usually a max. distance setting in the Refl/Refr. parameters. If used right it can cut down render times significantly.
Will a max. distance value an option for corona materials as well? Or I simply misunderstand the technical background of corona? Then please explain.
Many thanks…
maybe this was discussed before on the forum. I searched, but didn’t find it.
If rendering of reflective/refractive things goes exceptionally slow for you, then there is probably some error with the material config or render settings.
