I have a slightly heavy scene, but it’s really nothing compared to typical production. no matter if I use in viewport IR or popup IR every time I stop it, max goes into full grey spin freeze BS for minutes before recovering. super annoying.
Corona 3 hotfix1 default rendering settings, no weird or crazy values anywhere. It just looks like the viewport refresh that happens after or is being forced after the IR stops just kills max. it’s horrible, and I’m not sure if anyone else have noticed this?
I haven’t had time to setup a small simple scene, but I suspect the problem not being noticeable when the scene / viewport refresh is already super quick.
anyway any ideas would be amazing because this is driving me mad.
For more info, is denoising being used? And if so, the NVIDIA one or our High Quality one, and what GPU and image resolution if the NVIDIA one? EDIT well I guess just NVIDIA since you are talking about IR
I had it happen with both Nvidia on and off, but strangely enough the issue got less and less yesterday afternoon, nothing changed in the file, actually got more stuff in it, but compared to the last few days it isn’t a “problem” right now.
I’m not sure, I was wondering if it could be network problems, with the material editor refreshing every time?
I will certainly try and remember to dig out the dump, I was in the middle of a hectic 2 day delivery so frustration clouded my problem solving thinking a bit.
Yes, running corona 3 hotfix 1, I haven’t touched the dailies since 3 since it sounds like there is a bunch of stuff not quite working when reading the forums.
