I’m experimenting with using Max hair/fur modifier. It seems to render okay when in geometry mode (it’s behind glass), but I"m getting bad flickering when using Animation Prepass IRR mode. I should mention I’m using hair dynamics with a precomputed STAT file in case it matters.
What are the current limitations of using Max hair/fur modifier with Vray?
And if it does work, what are the most reliable techniques? Will IRR work, or do I have to go Brute?
