Anyone have a fix for the Max 2009 Design bug were the additional channels do not get saved out when submitted jobs to Backburner? Found a fix for 2008, hacking the OpenEXR.ini file, but nothing for 2009…it doesn’t seem to have the same ini file.
Only found this script, but it has to be ran for every Max file:
Thanks in advance
Out of curiosity… are you rendering your exr’s through the Vray Frame buffer? And if so, does the “Render Output” dialog in the Common tab show a filepath? We have had numerous issues on both Deadline and Backburner where our renders would not spit out their respective passes. We found that we had to run a simple maxscript in our files before submitting them to the farm.
Not rendering this through Vray’s FB, just standard Max…there are lot’s of posts on the Area about this issue but no solutions so far (Max 2009).
