Just in case you didn’t know, there is service pack available for Max (both flavours) on the support pages of the AutoDesk web site.
got a direct link?
thank you!
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11384420&linkID=9241178
Nowt interesting in there then.
i believe someone from our florida office said if you do a network install of max 2009, this service pack will cause issues.
gotta love this one:
Performance
A viewport performance issue related to the ViewCube has been resolved.
Apparently, installing SP1 will switch any Network Licensed install of 2009 to a stand alone and give you the 30 trial period in which to activate. Looks like a registry hack will fix it…
I had a similar warning pop up, after that I discovered that max 2009 and max design have two different SP1 ![]()
dowloaded the right one and everything works fine
I just got a message from mu reseller that there are apparently some issues with the Service Packs. They adviced to not install them yet, in case you haven’t done so…
I looked for a different one. Did I blindly miss the link to the Design SP1?
here is the link for max design SP1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11384587&linkID=10381720
yes thank you zeronove. I did go and find it after you mentioned it. One would think that there would be a warning or a link to the design version…
The screwy thing is that the Hotfixes installed with no problems… I hope that doesn’t mess anything up.
One of the issues is while working with light instances, you can’t use the light lister anymore.
This is a direct quote from my reseller and it’s all I know.
