If you hold shift and rightclick a spinner it will add a keyframe… usefull for animating spinners ![]()
15 - attaching multiple heavy objects in 3ds max via editable mesh/poly will perform a memory leak which will force max to jump the memory to maximum then crash. (test is done by cloning 100 (100x100) spheres and attaching them all in one batch. While if you attach them one by one your memory will grow exponentially, but you will be able to attache an nth number of them then save, close max open max and continue. (maya can do this attachement with memory under 900mb)
That’s true. But there is another trick about it. Just attach a few objects then type: → gc() ← into the white script/command line in the left lower corner. This should clear the cache and memory should be free again. ![]()
Good initiative.
Use ‘i’ to navigate and ‘[’ + ‘]’ to zoom towards your mouse cursor. very handy when you don’t want to cancel a selection sequence and still need to zoom/navigate.
ahh I didnt know about the zoom part of that one… Thanks Gijs 8)
cool tip ’ i always turn spinner up and then down in order to create key frame :lol:
F12 to open the transform type-in.
Alt-MMB to rotate view
Ctrl+Alt+MMB to zoom view.
RMB in rollouts to navigate to subrollouts.
Hope it helps any one.
Great idea for a topic.
… and what about starting also Maya tips&tricks session, because of new upcomming V-ray release for MAYA?
I’m pretty new to MAYA package but it seems to me like really powerfull tool.
I wish for V-ray for MAYA to be a christmas present for us
. … at least some kind of alfa build
jaro you can start a maya tips and tricks just not in this thread.
Here are a few of mine…..more if I can remember.
1. Further to Morbid’s :
To dynamicly work with modifiers you can drag and drop modifiers from one object to another. I.e. you have cube 1 and cube 2, cube 1 has meshSmooth on it, you can click and drag meshSmooth onto cube 2 and it will be copied there. You can hold down ctrl + drag will instace the modifier, shit+drag will move the modifier from one object to another.
If you select a modifier on the stack (use shift to select multiple) right click, you can copy it and paste it onto the modifier stack of another object. Useful for modifiers with lots of parameters such as a bevel that you want to apply to lots of objects.
2. Obvious one really but I don’t know how long it had been there before I noticed it
. There is a lock button at the bottom of the Render Scene dialogue box. Use to always render the camera view and not the current viewport.
3. Render Scene >> Common Parameters. If you right click on the resolution presets you can change them to values more suitable for your industry on a particular project.
4. AutoCAD & ADT Users. If you only model using the ‘3d solids’ commands and not the older ‘3d’ surfaces and primitives you will never get flipped surface normals when import into Max.
5. For anyone who ever does interiors, http://www.thesamplecentre.com has thousands of whole carpet tiles JPEGed ready to download.
6. Maya Users. You can successfully use VRay with Maya if you just change … Oh well that’s enough for now.
Dan
Thanks, didn’t know this one.
splendid link! cheers
Ever wonder why trim and extend in editble spline don’t always work that well?
try them in front or right view (not user or perspective).
Morbid, can you explain this in a little more detail
The reason is simple. Altough the GI calculations will take longer, the actual rendering will go faster because smoother GI means less work for the AA sampler. Same goes for glossies, sometimes increasing glossy subdivs actually decreases rendertimes.
It depends a lot on which image sampler you choose. (QMC or adapt subdiv).
ahhh i see now, i couldnt quite work out what morbid was getting at. Thanks for the clarification flipside!!
Dynedain wrote:
If you have an object and your points all need to be in the same plane (like say a wall where the top face has gotten distorted and the points aren’t all at the same height anymore) you can select all those points, and scale by 0% the dimension you want them aligned in. So in the case of this wall, select all the top faces, scale by 0% in the Z, and they will all be perfectly ligned up and ready to be put in the right Z location.
Is there an equivalent to this for an editable spline object? That is, is there any way of setting all the vertices of a spline to the same height in a given axis, including the bezier handles?
well what i usualy did was set the undo level to “1” then after that attach and deselect.. this should clear the cache.
Quote:
15 - attaching multiple heavy objects in 3ds max via editable mesh/poly will perform a memory leak which will force max to jump the memory to maximum then crash. (test is done by cloning 100 (100x100) spheres and attaching them all in one batch. While if you attach them one by one your memory will grow exponentially, but you will be able to attache an nth number of them then save, close max open max and continue. (maya can do this attachement with memory under 900mb)That’s true. But there is another trick about it. Just attach a few objects then type: → gc() ← into the white script/command line in the left lower corner. This should clear the cache and memory should be free again.
Use editable poly for attaching , from my experience it is more stable than mesh.
This does work for e.splines I believe. But you need to be in vertex mode. I don’t think it will fix bezier handles though.
open a new script and paste this into it (you can make a button out of it)
make sure you select a spline and you have no modifier on top it.
the script:
on isEnabled return
selection.count == 1 and \
(classof selection[1] == SplineShape or \
classof selection[1] == Line) \
and selection[1].modifiers.count == 0
on execute do
new_z = $.pos.z
for s = 1 to (numSplines $) do
for k = 1 to (numKnots $ s) do
knt = getKnotPoint $ s k
in_vec = getInVec $ s k
out_vec = getOutVec $ s k
knt.z = in_vec.z = out_vec.z = new_z
setInVec $ s k in_vec
setOutVec $ s k out_vec
setKnotPoint $ s k knt
)--end k loop
)--end s loop
updateshape $
