Hi all
Is there a way to set the default mode for viewport to shading mode? Everytime I restart max, it’s back to “realistic”
Hi all
HI Morné,
Have you tried tweaking your maxstart ?
It’s not something that gets saved within the max file. I’m hoping it’s a setting that is exposed via ini or maxscript
Oh ok, I wasn’t aware of this ![]()
Yeah, the realistic shade is never good with vray..
Weird, I restarted the pc, and now suddenly this is working (saves in the max file)
Hi Fernando,
Could you please develop a bit ?
Hi there, I meant that the realistic Rendering Level of the Viewport in real time is not that good as in Shaded Mode.. And most times I find the Orthographic mode way more precise to model..
Nothing too important, just to justify Morne decition to use shade mode over the Realistic default one.. capiche?
Ah yes, I understand. However, I tend to use Realistic mode quite often to place lights, so …
