I’m writing custom shader (derived from Shader class). Is it possible to use it in VRayMtl? Right now it is visible only in Standard material in “Shader Basic Properties”.
Hmm dunno if this is helpfull but look at the vraySDK help file for the MaterialInterface. maybe that will help you out.
No,
you have to use the VRay SDK and write a custom BRDF instead.
The math is the same though. Start with the samples.
Dieter
You cannot add a BRDF to VRayMtl itself; you have to code a new material (which you can combine with other materials using VRayBlendMtl). In the SDK for newer builds there is a sample code for a simple Blinn material.
Thanks for Your help.
Vlado: I have 1.5RC3 which is latest build AFAIK and I don’t see any sample for Blinn material.
maybe he means newer then rc3? seems people are working with it but it’s nowhere to be found
thing some soft of beta or sumthing.
edit : have you looked into the Chaosgroup directory when in your program files? there are a couple of samples you could have a look at.
It’s like hunting a fly with a cannon. Some simple support for custom shaders would be nice feature in next releases of SDK. ![]()
As far as V-Ray is concerned, there isn’t much difference between coding a material, and a shader (a material IS a shader, after all). Being a 3ds Max plugin, your shader must still contain lots of code related to 3ds Max; the V-Ray portion of a material is typically 5 to 10% of all the code
V-Ray at least provides you with an automatic UI generation for your plugins.
Yes, I have, but I haven’t found example for blinn material.
It’s for newer builds not the RC3.
If I understand correctly, we will able to adapt this exemple to create custom shaders ? It’s like a skeleton.
