Probably better if posted in off topic but…I could not use Vray.
Got my Vistas 64 bits Open licences today..installed easily…photoshop etc.
But Max9 DOES NOT WORK in Vista :evil: :evil: :evil:
Browsing Autodesk foruns…
Any workarrounds?
I am hopping for a MaxSp1..
I’ve had Max running on Vista with DirectX without too many problems.
First I had to disable Aero - this caused directX viewport issues.
Second, I had to run Max as an administrator (if I remember correctly, you right click on the Max shortcut and select run as administrator)
The above worked for me although I had other issues with Vista so I’ve since returned to Win XP Pro.
You can buy a Mac that runs with Intel processors, make a dual boot and run 3dmax ( there is also a few benchs in the forum ).
And I can not (so far) run Max9 64bits on a new windows OS :shock:
