Hi Guys,
Tell me, anyone here succesfully uses PSD manager under MAX9?
Mine stopped working, seems like the PSD manager is no longer compatible with 3d MAX ?? Is that true?
I`m pretty addicted to it.
You probably need to get a version of PSD manager specifically compiled for 3dsmax 9 (the 3dsmax 8 version will not work). I’m sure that if you ask Daniel on the cebas forum, he will be able to answer.
Thanks for answering, I`ve checked the CEBAS website - they state that PSD manager is compatible with MAX9 now, so I recon, that they`ve released an update. I must chase them to get one
The psd-manager 2.0 Update is available since January and compatible to Autodesk 3ds max 6/7/8/9 (32-bit and 64-bit) or VIZ 2005/2006/2007. Here is the link to the press release.
